• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    How to place the “midpoint” of window on the midpoint of wall?
    155 Views, 2 Replies
    10-01-2012 02:02 PM
    In the screenshot below, I wanted to place the window from its midpoint to the midpoint of the wall. How this can be performed on Revit?
    Thank you
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Re: How to place the “midpoint” of window on the midpoint of wall?
    10-02-2012 06:20 AM in reply to: JamaL9722060
    Place the Window, create a dimension between the faces of the outer walls, and click the "EQ" to make the distances equal. (see image)
    You can then remove the dimension afterwards if you wish, and either retain or remove the constraints.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    JamaL9722060
    10-02-2012 01:38 PM in reply to: CADastrophe
    Many thanks for the answer. I like your screenshot.
    I feel that this is very exhaustive. We need to work with dimensions more than working with snaps!
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
