How to label all the windows at a time with serial number?
JamaL9722060
JamaL9722060
I’m wondering if there is a way to label all the windows at a time with serial number.
Thank you
Best
Jamal
Jamal Numan
CoreyDaun
What you need to use is the "Tag All Not Tagged" command (which is shown as "Tag All" on the Ribbon icon), located on the Annotate tab. You can either select a group of elements (which don't all have to be Windows) or you can simply activate the command, which then applies to all elements visible in the current View. A dialog box will appear with a list of available Tags for each Category. Select the Window Tag you want to use, and each Window in the selection range will be Tagged with the selected Tag. If an element is already Tagged, Revit will not Tag it again with this tool.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
JamaL9722060
Many thanks for the answer. This is very helpful.
Best
Jamal
Jamal Numan
