• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    How to label all the windows at a time with serial number?
    250 Views, 2 Replies
    10-01-2012 02:11 PM
    I’m wondering if there is a way to label all the windows at a time with serial number.
    Thank you
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Re: How to label all the windows at a time with serial number?
    10-03-2012 06:27 AM in reply to: JamaL9722060
    What you need to use is the "Tag All Not Tagged" command (which is shown as "Tag All" on the Ribbon icon), located on the Annotate tab. You can either select a group of elements (which don't all have to be Windows) or you can simply activate the command, which then applies to all elements visible in the current View. A dialog box will appear with a list of available Tags for each Category. Select the Window Tag you want to use, and each Window in the selection range will be Tagged with the selected Tag. If an element is already Tagged, Revit will not Tag it again with this tool.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    JamaL9722060
    10-03-2012 02:30 PM in reply to: CADastrophe
    Many thanks for the answer. This is very helpful.
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
