• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    lucilarosso
    Accepted Solution
    How to determine the total length of multiple lines
    6779 Views, 16 Replies
    01-18-2012 10:47 AM
    This is something that used to be very easy to do in autocad (with a polyline) and checking the lenght on the properties bar.
    When I select multiple lines (chain of lines) the "lenght" data is greyed out.
    I hate having to measure every segment separately! It has to be easier... right?
    Please use plain text.
    Employee
    Re: How to determine the total length of multiple lines
    01-18-2012 11:47 AM in reply to: lucilarosso
    use the Measure tool, using measure between two elements, ad check on the Chain option in the Options bar.
    Scott D Davis
    AEC Technical Specialist
    North American Sales
    Autodesk, Inc.
    Want Revit Content? Go to http://seek.autodesk.com !
    *Expert Elite*
    Alfredo_Medina
    01-18-2012 11:59 AM in reply to: lucilarosso
    Or, maybe faster, without checking Chain, is: Measure > Measure Along an Element. Hover the mouse over the first item, hit the tab key, and click. The result of the total length would be in the options bar.
    Planta1 Revit Online Consulting | info@planta1.com
    Member
    lucilarosso
    01-18-2012 12:25 PM in reply to: Alfredo_Medina
    It seems that both solutions involve measuring again everytime the chain of lines are modified. Not ideal to me.
    A friend suggested using a spline line with a very tight radius at the corner- it generates an overall lenght on the properties. Seems to be working. Thanks!
    *Expert Elite*
    Alfredo_Medina
    01-18-2012 12:54 PM in reply to: lucilarosso
    Not a good advice from your friend. Splines have other issues. Have you tried to use Trim/Extend with splines? You are creating a new set of issues for not doing one extra click with the Measure tool.
    *Expert Elite*
    01-18-2012 02:03 PM in reply to: lucilarosso
    Can you tell us specifically what you're trying to measure?  If it's path of travel, then I'd recommend using a line-based generic model element, and then generating a schedule that stays up-to-date with the total length.  If it's something else, there might be a better way, but it's hard to say without knowing exactly what you're doing.
    Ross Kirby
    BIM Manager
    Arcturis
    Member
    lucilarosso
    01-18-2012 03:08 PM in reply to: lucilarosso
    Correct: I am trying to measure a path of travel.
    What you are suggesting sounds quite complex ....  Wonder whether I might as well measure every line instead.
    But if not too much trouble, I am curious to hear more.
    *Expert Elite*
    Alfredo_Medina
    01-18-2012 08:38 PM in reply to: lucilarosso
    Then the proper question to start this thread with was "How to create and measure an egress path?" instead of "How to determine the total length of multiple lines?"
    *Expert Elite*
    01-19-2012 05:55 AM in reply to: lucilarosso
    It's actually not that hard, even though it sounds a little complicated.  The method I use is shamelessly stolen from Steve Stafford's blog, where he provides the families and schedules you'll need to get the job done.
    http://revitoped.blogspot.com/2007/01/egress-path.html
    Ross Kirby
    BIM Manager
    Arcturis
    Member
    lucilarosso
    01-19-2012 06:45 AM in reply to: rosskirby
    Thanks! I'll give it a try.
