• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    How to determine the distance between the two “flights” of the stair?
    133 Views, 2 Replies
    11-04-2012 10:08 AM
    I couldn’t find the option through which the distance between the two flights is determined.
    Also, I have no idea how to create another landing at the end of the stair!
    Thank you for the help,
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Member
    Re: How to determine the distance between the two “flights” of the stair?
    11-05-2012 11:03 AM in reply to: JamaL9722060
    You need to edit the stair sketch to change the dimension between the flights. You can also edit the stair sketch to increase the length of the last tread to make it a landing by moving the last line.
    JamaL9722060
    11-06-2012 01:16 PM in reply to: SomeIdeas
    Thank you for the answer.
    In the screenshot below, I attempt to change the length of the distance betwwen the two flights but sounds that there is no option to do that!
    What might be the solution?
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
