• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    Accepted Solution
    How to delete a particular “dimension line”?
    340 Views, 4 Replies
    10-02-2012 02:06 PM
    I wanted to delete one of the “dimension lines” but sounds to delete all the connected dimension
    Best
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    parveen.revit
    Re: How to delete a particular “dimension line”?
    10-02-2012 10:23 PM in reply to: JamaL9722060
    you can select that dimension and click on the reference point/element to remove that dimension.
    that distance (dimension value) will be added to next dimension.
    direct delete is not possible.
    Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
    JamaL9722060
    10-03-2012 02:07 PM in reply to: parveen.revit
    Thank you for the answer.
    For example, in the screenshot below, I wanted to delete the dimension 1.4, but couldn’t know where to click in order to delete it.
    Firefox 20.0,
    Kaspersky 2013.
    *Expert Elite*
    10-03-2012 02:14 PM in reply to: JamaL9722060
    In Revit 2013, you can hover the mouse over a segment of continuous dimensions, press tab to highlight that particular segment, and delete it.
    This is not possible in prior releases of Revit.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    JamaL9722060
    10-05-2012 01:41 AM in reply to: CADastrophe
    many thanks. this is much easier.
    best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
