• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    m9905101
    How to create a ceiling which is vertical with horizontal ceiling
    175 Views, 1 Replies
    05-27-2012 05:12 AM
    I want to create a ceiling whcih is vertical with the floor in order to put air terminal in MEP. But the general ceiling is horizontal to floor. Does anyone how to create it? Thanks for replying.
    Please use plain text.
    Milos_Vajdic
    Re: How to create a ceiling which is vertical with horizontal ceiling
    05-27-2012 05:46 PM in reply to: m9905101
    If you do Component>Model in Place and select Ceiling from the options, you can then draw/create a ceiling you want with extrusion tool.
    That should do the trick.
    Milos
