• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    How to activate snap tools?
    102 Views, 1 Replies
    11-06-2012 06:53 AM
    I've just recently started to try using Revit architecture, most of it seems fairly self explanitory however I've had trouble because I don't know how to get the snap tools (like those found on autocad) to work.
    The First situation I want to solve is positioning a steel I-frame column to the center of a pad foundation. However when it comes to moving the column or just trying to create it in the centre no points appear to help me position it?
    Please use plain text.
    *Expert Elite*
    Re: How to activate snap tools?
    11-06-2012 06:59 AM in reply to: maxcallaghan
    http://wikihelp.autodesk.com/Revit/enu/2012/Help/Revit_User's_Guide/2921-Customiz2921/2931-Project_2...
    You should be able to snap to the midpoint of the footing to correctly position the column.
    Use the Tab key to cycle thru possible elements when selecting/moving/snapping.
    Also, use keyboard shortcuts such as SM for Snap Midpoint, SC for Snap Center, SP for Snap Perpendicular, etc.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
