• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    twilks1
    How to Reference Views from linked files
    268 Views, 3 Replies
    09-12-2012 07:19 AM
    I have thought about this and want to get input on a best approach to utilizing Views created in a linked Revit project file. One need is to create a Callout within the current Revit project and reference a view from another linked project. This is a common need in many of our projects and any input would be appreciated.
    Please use plain text.
    Re: How to Reference Views from linked files
    09-13-2012 05:53 AM in reply to: twilks1
    Revit is not very good at referencing information from other files, even ones that are linked. I don't believe that this is possible. For a similar purpose, we have create a Detail Item that mimics the appearance of the Callout, has adjustable length/width, and includes a fake tag. We even made the label a Shared Parameter so we can create a Schedule to keep track (if we have a lot of them) and easily locate them to verify that they have a correct reference.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Product Support
    09-20-2012 03:32 PM in reply to: twilks1
    There is an open wishlist item for the ability to access views from a linked Revit project.
    If you would like to submit feedback directly to our development group on how this feature would affect your workflow, you can use the following link: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
    Lance Coffey
    Support Specialist
    Product Support
    Active Contributor
    twilks1
    09-20-2012 03:44 PM in reply to: CADastrophe
    Yep, we do it that way too. I was fishing for new ideas or tricks because I hate dumb connections.
