• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    pt
    Active Member
    Re: Help needed about Revit Server 2013
    08-02-2012 09:02 AM in reply to: ccollins
    All done by the book (In this case video). I'm wondering, could you make a rsn.ini file on a workstation with dummy host entrys and see them from Revit? I belive it should be possible!
    Could someone make the test for me?
    Regards
    Peter Tranberg
    NTI CADcenter, Denmark
    revitogbim.blogspot.com
    Please use plain text.
    08-02-2012 09:03 AM in reply to: pt
    Here is another good one:
    http://wikihelp.autodesk.com/Revit/enu/community/videos/Revit_Server/WAN
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    pt
    Active Member
    08-02-2012 09:29 AM in reply to: ccollins
    Yes Cliff, I follwed that to. Great stuff, but it doesn't work for me. I have now posted the Issue to Product Support. But if you could try the test I suggested, I would be glad to here the result.
    Regards
    Peter Tranberg
    08-02-2012 11:20 AM in reply to: pt
    We do not have RS 2013 online yet; only RS 2012--not sure if the test would work?
    We are planning to roll out RAC 2013 and RS 2013 in the next week or so.
    Cliff B. Collins
    St. Louis, MO
    Alfredo_Medina
    08-02-2012 02:39 PM in reply to: pt
    I don't understand the test that Peter is proposing. If I put a dummy name in the rsn.ini file, I won't be able to connect. The name in the file must match the name of the server that you are trying to connect to, or it's IP address.
    Planta1 Revit Online Consulting | info@planta1.com
    DarrenP
    08-02-2012 02:50 PM in reply to: Alfredo_Medina
    the reason would be to see if revit can see the dummy server name
    i guess to be able to test to see if the rsn.ini is working?
    which it should be able to
    you just can't connect to it
    pt
    Active Member
    08-02-2012 11:10 PM in reply to: DarrenP
    You are right DarrenP. The test is not to connect to the server, it's only to se if Revit is able to show the host servers to search for. You don't have to have a Revit Server2013 to test.
    Regards
    Peter Tranberg
    Alfredo_Medina
    08-03-2012 06:58 AM in reply to: pt
    Peter,
    Please contact me by email, and we can arrange a GotoMeeting session, and share the screen, and do the tests.
