• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    *Expert Elite*
    Alfredo_Medina
    Help needed about Revit Server 2013
    1032 Views, 17 Replies
    05-03-2012 06:42 AM
    I would appreciate some help understanding the new behavior of Revit Server, in 2013. I used to have Revit Server 2012 in my server, and I used to be able to connect from my laptop and see the folders that I had created in the server, open the folder, and save the file, but now, in 2013, even though I have followed the instructions, and I can connect to the server,  I can't see, from my laptop, the folders that I have made in the server. I wonder if this has anything to do with my choice for those 3 options that appear at the time of installation: Host, Accelerator, and Admin. I chose all three.
    This was the workflow in Revit Server 2012:
    In Revit 2012, the icon to connect says "Connect to Revit Server" , I could connect, and then when I went to save, in the file dialog box, I had an icon that looked like a server, and was named simply as "Revit Server", which I could open and see my folders, and save my files. Everything was OK.
    This is what happens in Revit Server 2013:
    The icon to connect says "Manage connection to a Revit Server accelerator" , I can connect to the server, and then when I go to save, in the file dialog box, the icon now says "Revit Server Network", different name, but when I go to save, in the file dialog box, I can't see the folders that I have created in the server.
    • I set up the RSN.ini file, and I can connect to the server correctly; the connection is not the problem, but where are my folders?
    • The new names, "Manage connection to a Revit Server accelerator" instead of "Connect to Revit Server" and  "Revit Server Network" instead of "Revit Server", are those the new standard names, or are they a consequence of the choices I made during the installation?
    Planta1 Revit Online Consulting | info@planta1.com
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: Help needed about Revit Server 2013
    05-03-2012 05:25 PM in reply to: Alfredo_Medina
    Never mind. I found the answer. The same RSN.ini file needs to be in both places, server and remote user.
    pt
    Active Member
    08-02-2012 03:37 AM in reply to: Alfredo_Medina
    If both rsn.ini files are there but stil no servers visible, what to do then?
    Peter
    Regards
    Peter Tranberg
    NTI CADcenter, Denmark
    revitogbim.blogspot.com
    *Expert Elite*
    Alfredo_Medina
    08-02-2012 04:53 AM in reply to: Alfredo_Medina
    Hello, Peter, nice to see you here. I recommend you these 3 alternatives of help:
    1. Ask an IT consultant. Most issues about Revit Server's connection are their territory, not ours.
    2. If you are under subscription, send question to Autodesk's Support. I did it and I got a quick reply by Lance Coffey.
    3. Read all about Revit Server in Wikihelp.
    4. Watch videos in Youtube and in the Wiki.
    5. Ask Cliff Collins. He is very well informed about this.
      http://forums.augi.com/showthread.php?140287-Revit-Server
    Probably you have already done all of the above, except # 5?
    pt
    Active Member
    08-02-2012 05:20 AM in reply to: Alfredo_Medina
    Thanks Alfredo
    I have done all that exept Product Support and contacting Cliff Collins. I will try Product Support.
    Regards
    Peter Tranberg
    *Expert Elite*
    08-02-2012 07:23 AM in reply to: Alfredo_Medina
    I'm not sure I have the answer about having .ini files in all locations, but still no connectivity ( if I have the problem right?).
    I'd check IIS setup, ping all servers from each location.
    Also, an obvious one that sometimes gets overlooked is having Silverlight installed with latest version at all locations.
    Does the Revit Server Admin web portal show anything in your browser?
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    pt
    Active Member
    08-02-2012 07:37 AM in reply to: ccollins
    Hi
    Yes, I can connect and ping all servers, we have one with roles Host,Accelerator,Admin and one with roles Accelerator,admin. I can also reach both servers with http://<servername>/revitserveradmin2013 from my workstation, and see the folderstructure that I created.
    The rsn.ini file is created on both servers and the workstation. As shown in this video http://thejame.wordpress.com/2012/04/21/revit-server-2013-revit-model-collaboration-across-lan-wan/#...
    It should also be possible to see any host entry in the rsn.ini and see them even if they are "Ghosts" as in not present on the network.
    Nothing shows up in the Revit workstation, not at open and also not when trying to save a workshared project. My firewall is checked for Files & Printers on the workstation as required.
    Regards
    Peter Tranberg
    *Expert Elite*
    08-02-2012 08:27 AM in reply to: pt
    http://wikihelp.autodesk.com/Revit/enu/community/videos/Revit_Server/Configuring_Revit_Server_Prereq...
    make sure all these steps have been followed.
    Cliff B. Collins
    St. Louis, MO
    *Expert Elite*
    Alfredo_Medina
    08-02-2012 08:48 AM in reply to: Alfredo_Medina
    Thanks, Cliff, for the link to that video. It's the best video I've seen about that installation. Thanks.
    *Expert Elite*
    08-02-2012 08:51 AM in reply to: Alfredo_Medina
    Yes--those are good reference videos. Esp. for us "archies" who are also trying to be "IT gurus"! :smileyhappy:
    Cliff B. Collins
    St. Louis, MO
