• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    MrTikeraaq
    Having technical problems with Revit Architecture 2012
    215 Views, 1 Replies
    01-17-2012 10:02 AM
    Hello.
    My name is Magnus, I am 18 years old and studying architecture.
    When I launch Revit Architecture 2012, i come to a menu where i can choose between the following:
    Basic Sample Project
    Advanced Sample Project
    Basic Sample Family
    Advanced Sample Family
    Getting Started Video.
     When I click either of the 4 top choices, the program starts to load, but after a few seconds it crashes and will no longer "Respond".
    I have tried giving it time (from 2 seconds to 20 minutes), but regardless of this, it will still crash. I have tried to use the Windows Repair tool to see if that had any effect, but it didnt.
    My system should meet the requirements (as far as i am concerned?), details of my system are at the bottom of the page.
    When the crash happens it does not give an error message, it just stops responding.
    So I just wanted to hear if you have any solutions to what I could do to make it work properly?
    OS Name Microsoft® Windows Vista™ Business
    Processor Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz, 2394 Mhz, 2 Core(s), 2 Logical Processor(s)
    Installed Physical Memory (RAM) 4,00 GB
    System Model Dell DXP061
    Please use plain text.
    Valued Mentor
    MarySeufert
    Re: Having technical problems with Revit Architecture 2012
    01-17-2012 10:30 AM in reply to: MrTikeraaq
    Hi Magnus,
    For your future posts, this is the AutoCAD Architecture forum, not the Revit Architecture forum. I pulled the specs below from the Revit System Requirements page. From what I can tell, your system does not have a strong enough processor, and if your system is 64-Bit, you do not have enough RAM.
    For 32-Bit Autodesk Revit Architecture 2012
    • For Microsoft Windows 7 32-bit or Microsoft Windows Vista 32-bit: Intel® Pentium® 4 or AMD Athlon™ dual core processor, 3.0 GHz (or higher) with SSE2 technology
    • 4 GB RAM
    • 5 GB free disk space
    For 64-Bit Autodesk Revit Architecture 2012
    • ForWindows764-bitorWindowsVista64-bit: Intel® Core™ i5-2300 quad-core processor (2.8 GHz, 6 MB cache) or equivalent AMD® processor.
    • 8 GB RAM
    Good luck, Mary
    ___________________________________________________________________
    Normal people believe that if it ain't broke, don't fix it.
    Software Engineers believe that if it ain't broke, it doesn't have enough features yet.
