• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    kate_vanhout
    Garage Floor Drain Family
    228 Views, 3 Replies
    12-06-2012 02:58 PM
    I would like to create a family for our garage floor drain... I would like to be able to place the family on the main/garage level floor plan but I would also like it to show up on the foundation plan, but without putting another family on the foundation plan because I only want 1 garage floor drain to show up in my schedules.  Does anyone have any ideas on how to do this!?
    Please use plain text.
    Alfredo_Medina
    Re: Garage Floor Drain Family
    12-06-2012 04:27 PM in reply to: kate_vanhout
    A family with a vertical invisible line, maybe controlled by a parameter to adjust as per the depth of the foundation, will show the fixture at the level of placement, and also at the lower level, and will report just once in the schedule.
    Planta1 Revit Online Consulting | info@planta1.com
    Valued Contributor
    kate_vanhout
    12-07-2012 05:50 AM in reply to: Alfredo_Medina
    Thanks so much!! :smileyhappy: that work like a charm.  Is there any possible way to make something different show up on the basement? forinstance, We show our garage doors looking like a garage door on the main level, but then just a hatch in the concrete in the basement.  Is there a way to make that work!?
    Alfredo_Medina
    12-07-2012 06:56 AM in reply to: kate_vanhout
    I don't know. Keep in mind that it is the same family, shown in two different levels, so whatever changes you do to the family, will be shown in both levels. If you hide or show anything on the foundation plan, that is going to be shown or hidden in the level above as well.
