...if I am to understand correct, perhaps using that small exterior wall
that returns...just this side of the exterior door would help.
I'd first select that one and attach it to the upper roof.
Then in plan, create your new wall aligned with the short wall, start where
the short one stops and extend to short wall on other side of building. Base
constrain offset as you see fit, and attach the top to the upper roof. You
should be able to edit the roof line of the lower roof to butt up against
your new wall.
not sure if that makes sense, but that's what I'd be trying...mainly because
I'm too new to Revit to know another way.
David Ford
Migrant Technical Laborer
"Reinvention is requisite to life in an impermanent Universe."
wrote in message news:5259723@discussion.autodesk.com...
That was along the lines of what I was thinking, but the wall would only
attach it's top to 1/2 of the higher roof, and poked through the other half,
possibly because the wall base and roof sill are the same? I guess an offset
might fix that. My other problem is getting the lower roof to extend to the
gable wall so I can attach/detach it in the first place. I tried making two
roofs, but couldn't get the part of the two roofs that are in the same plane
to clean up nicely (meaning at all).
