• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    Fuzzy Grids, Annotations, and Navigation Bar / Wheel
    129 Views, 1 Replies
    01-27-2013 11:22 AM
    Help! Certain elements in my Revit files are not displaying correctly. All building elements (floors, stairs, families, walls, etc) show up correctly, but any annotations or gridlines are missing or seem broken and fuzzy. The same appearance issue is happening with the upper right hand tools (Nav Bar, Orbit Wheel, Max / Min / Exit buttons). It is happening in both Revit 2012. Revit 2013, and in all new or opened projects.
    I have attached images. Thank you for your help or suggestions!
    Please use plain text.
    Re: Fuzzy Grids, Annotations, and Navigation Bar / Wheel
    01-28-2013 04:32 AM in reply to: katherine.bausch
    Hi Katherine,
    2 things to check..............1st, make sure the drivers for your graphics card is up to date......2nd, check your options to see if "Hardware Acceleration" is on (or off).  If 'checked', un check and see if that correts the problem.  Vise-versa if not.
    Mike
    Michael L. Maloney
    Virtual World Designs
    VDC & BIM Model Design, Clash & Coordination
    mike@VirtualWorldDesigns.com
    Building Design Suite Ultimate 2013
    Charlotte/Gastonia, NC & Jacksonville, Fl.
