• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    OZRevit
    Flexing a blend above a column
    305 Views, 5 Replies
    05-22-2011 09:15 PM
    Made a concrete column family and a blend to go on top of the column (as a seperate family).
    All works fine (in terms of flexing) except that when I flex the column, it goes right through the blend above it!
    How do I get the column to flex (Up or down) so that the blend above it also moves?
    Thanks in advance
    Please use plain text.
    Product Support
    alan.quinn
    Re: Flexing a blend above a column
    05-23-2011 12:01 PM in reply to: OZRevit
    Align and lock the blend to the top of the column. See attached image.
    Hope this helps,
    Alan Quinn
    Support Specialist
    Product Support
    Autodesk, Inc.
    OZRevit
    05-23-2011 03:55 PM in reply to: OZRevit
    Thanks for the reply, I did align and lock the blend to the top of the column, when I flex the column, I get "Constraints are not satisfied"
    I attached the file, please advise.
    Many thanks
    Product Support
    alan.quinn
    05-24-2011 10:49 AM in reply to: OZRevit
    See the attached file. I added the blend to your column.
    Hope this helps.
    Alan Quinn
    Support Specialist
    Product Support
    Autodesk, Inc.
    OZRevit
    05-24-2011 03:38 PM in reply to: OZRevit
    Thanks for your help Alan.
    This is not the file I sent you though...how do I fix the problem in my file?
    Product Support
    alan.quinn
    05-25-2011 06:52 AM in reply to: OZRevit
    You have to align and lock the bottom edge of the blend to the Top Ref Plane. See the attached.
    Thank you,
    Alan Quinn
    Support Specialist
    Product Support
    Autodesk, Inc.
