• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    Fixing grid heads in place
    101 Views, 2 Replies
    12-14-2012 01:15 PM
    Is it possible to fix the grid heads in place in one view without having them move in all views?
    Please use plain text.
    Re: Fixing grid heads in place
    12-14-2012 01:20 PM in reply to: zrbrock
    Yes. Use a Scope Box. Then highlight the Grids you want to stay in position, and then in Properties, select the Scope Box to associate those Grids to.
    The other Grids have not Scope Box association.
    Then, in your View that you want the Grid Bubbles in a certain position, apply the Scope Box.
    ( I would have to test this to be sure it does what you are asking.)
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Active Contributor
    sagar.londonites
    12-14-2012 08:11 PM in reply to: zrbrock
    zrbrock,
    When you select the grid, you'll notice a "3D" text near the head. Click on it and it becomes "2D".
    Now you can move the grid head in any way and that would not affect grid head in other views.
    - Sagar
