• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Member
    anderj24
    Extensions.Buffers
    213 Views, 2 Replies
    07-13-2011 02:18 PM
    I have noticed the added parameters of 'extensions.buffer1,extensions.buffer2,extensions.buffer3,...etc' after having installed subscripitons advantage tools.
    1) Is there a way to tell which user id created the parameters?
    2) How are they use, I have not seen them filled in at any points?
    3) How do we delete them once they are in a Project, or can we?
    Please use plain text.
    Product Support
    Re: Extensions.Buffers
    07-18-2011 06:14 AM in reply to: anderj24
    These are shared parameters automatically created by the Revit Extensions (the source file can be found at C:\Program Files\Common Files\Autodesk Shared\Extensions 2012\Products\Revit\REXParams.2012.txt). These parameters are used internally by the Extensions, so I would not recommend removing them.
    I hope this helps!
    Katie Langan
    Revit Support Specialist
    Autodesk, Inc.
    Revit Clinic
    Member
    anderj24
    07-18-2011 07:06 AM in reply to: kathryn.langan
    Katie,
    Thanks for the reply. I would still like to know if there is a way to tell what User id and Date it was created.  Ultimately I want to track the use of these parameters. I dont necessarily want to have to take all Extensions off all computers.
    For instance if I am a Subcontractor using the Extensions for a Client who is not, will my machine populate the Extensions Parameters into their model?  If so How do I clean them up?
    Or if I am a  BIM Manager using the tools to asses a model in my office how do I get the extensions parameters out of the model when I am done and we are submitting the model?
