Autodesk Revit Architecture
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Extend columns to curved roof
Options
- Highlight
- Email to a Friend
- Report Inappropriate Content
136 Views, 7 Replies
11-15-2004 04:35 PM
How do I extend steel UC columns to a curved roof?
*Jeffrey McGrew
Re: Extend columns to curved roof
Options
- Highlight
- Email to a Friend
11-17-2004 10:10 AM in reply to:
sparrowitis
Columns in Revit don't attach automatically to a roof above or a slab
below like walls can. Don't know why, probably just haven't added that
ability yet. Anyways, there are three ways to do it, first you can
simply use the top offset on the columns to make each collum penetrate
slightly into the curved ceiling, and then use the join geometry tool
to have it clean up the edges (I think this works); or you can use
little sections of walls instead of column families (but that won't
give you a steel shape, just a square or circle); or you can model
them as an in-place family, and make them any shape you want so that
they perfectly join into the curved roof (but then they become hard to
move around and such)...
Jeffrey
Options
- Highlight
- Email to a Friend
11-17-2004 03:08 PM in reply to:
sparrowitis
Thanks Jeffrey. In the end I found the easiest way was to create levels "Column 1,2,3" etc and use the top offset, then hide the annotations in all the views (a bit time consuming - I wonder if there is a way to select them all at once?)
*Paul Monsef
Options
- Highlight
- Email to a Friend
11-17-2004 04:52 PM in reply to:
sparrowitis
> I wonder if there is a way to select them all at once?)<
If you right-click a family type in the project browser you will see a
"Select all occurrences" option. ;o)
Paul Monsef
TSA | architects, pllc
Production/CAD Manager
425.401.6828 x105
paulmonsef_NOSPAM_@tsaarchitects.com
"sparrowitis" wrote in message
news:31611922.1100732922306.JavaMail.jive@jiveforu m1.autodesk.com...
> them all at once?)
Options
- Highlight
- Email to a Friend
11-18-2004 12:42 AM in reply to:
sparrowitis
Hmmm, but the "Column 1,2,3" etc levels which I want to hide are the same family as the levels Ground, Level 1 etc. which I want to show. How can it differentiate? Can I make 2 different families for the 2 types of levels?
*Paul Monsef
Options
- Highlight
- Email to a Friend
11-18-2004 08:58 AM in reply to:
sparrowitis
Oh, I misunderstood...Silly me... You can only hide them one at a time even
if you select more then one level.
Paul Monsef
425.401.6828 x105
news:4250979.1100767402749.JavaMail.jive@jiveforum 2.autodesk.com...
Options
- Highlight
- Email to a Friend
11-18-2004 08:04 PM in reply to:
sparrowitis
It would be great if you could hide multiple annotations at once. I had to go through that routine 50 times when I created those dummy levels.
*Jeffrey McGrew
Options
- Highlight
- Email to a Friend
11-18-2004 10:36 PM in reply to:
sparrowitis
not to be mean, but that's why you don't create extra 'dummy' levels
in the first place and instead use the offset for base/top features.
In this case you chose the former, which is totally OK and all, but
the more levels you add to your project the more you increase it's
complexity. Levels are really ment for major project datums I feel,
and I only create a new one when it's really really needed. This also
really helps in the future when dealing with RCP's and sections and
such...
Jeffrey McGrew
