• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    Exporting to Cad Settings
    142 Views, 2 Replies
    09-17-2012 09:18 AM
    Few quick questions, I am trying to configure the exporting settings. thanks for you help in advance.
    In the Modify DWG/DXF export Setup, where do you find the "aia standards" fille that is in the load layers from standards option? I want to get that file and atler it.
    Also what does the {underlay} modifier mean?
    thanks
    Please use plain text.
    Re: Exporting to Cad Settings
    09-18-2012 10:36 AM in reply to: lhmoman
    iS COLOR_ID in the export tag meant to overide in color option only and not line weight  and layer?
    09-18-2012 11:27 AM in reply to: lhmoman
    lhmoman wrote:
    "In the Modify DWG/DXF export Setup, where do you find the "aia standards" fille that is in the load layers from standards option? I want to get that file and atler it."
    Try looking under C:\Program Data\Autodesk\RME 20** for the file exportlayers-dwg-AIA.txt
    lhmoman wrote:
    "Also what does the {underlay} modifier mean?"
    I think that this would apply to anything that is part of an Underlay of a View (View Properties » Underlay).
    lhmoman wrote:
    "iS COLOR_ID in the export tag meant to override in color option only and not line weight  and layer?"
     I believe that only sets the color of the destined AutoCAD Layer. The layer is assigned a proper Lineweight.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
