• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    Exported Text height
    157 Views, 2 Replies
    04-06-2011 12:49 PM
    When I exported my project to AutoCAD, the 1/8" text from Revit exported as 5/32". This happened with multiple different text sizes across the project. Has anyone else had this issue?
    Other examples i have ssin in my project:
        3” is exporting as 3 9/16”
        1.5” is exporting as 1 25/32”
        1” is exporting as 1 3/16”
    Please use plain text.
    RNDPIS
    Re: Exported Text height
    04-08-2011 05:31 AM in reply to: munsellh
    My Suggestion is:
    Please check the Unit (inch) and Text treatment (Maintain functional fidelity) when you export the revit project. See the attached jpg.
    04-14-2011 11:40 AM in reply to: RNDPIS
    Units are set to inches and I have tried both options for text treatment. same results either way. Just curious have you had this issue and did that fix it for you?
    HJM
