• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Export to CAD Dimension Inaccuracy
    232 Views, 1 Replies
    07-15-2011 05:55 PM
    I have a project in REVIT that I had to dimension soft metric - both imperial and metric.
    I double dimensioned everything, one dimension type imperial and one metric. In revit, I then moved one of the dimensions below the dimension stringer. Everything looks as I want it in REVIT
    When I export the file, the font of the texts change, and the location of the text I moved goes back to it's initial location.
    Any fix for this?
    See attached pic
    Please use plain text.
    Re: Export to CAD Dimension Inaccuracy
    08-01-2011 11:23 PM in reply to: kai.alaska
    Can you upload a sample.
    Which font are you using, (I know you must be having project specific or company specific font but once try with Arial if it works fine, when you export. I dint have issues).
    Raghavendra Bhat,
    rnbhat1@gmail.com,
    Revit Architecture 2010 Certified Professional.
