Autodesk Revit Architecture
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Editing wall material to concrete in plan view
- Highlight
- Email to a Friend
In floor plan view how do I make a wall have a concrete texture inside instead of the default (criss cross)?
Re: Editing wall material to concrete in plan view
- Highlight
- Email to a Friend
Under Wall Properties, Edit>Structure>Materials--change to Concrete for the Cut Pattern.
The "criss-cross" pattern is typically for Concrete Masonry Units ( block), so you should really use a different Wall Type
and name it Cast In-Place Concrete, then specify the correct Material and Fill Pattern.
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
- Highlight
- Email to a Friend
Thank you. I have made a new wall how you said, changing the material to cast-in place concrete instead of concrete blocks and on the preview for the wall it is perfect but when I draw the line on the floor plan it still has a criss-cross pattern. I have attached a picture where you can see how the wall looks in the properties preview and on the floor plan it is highlighted.
Thank you,
Yehuda
- Highlight
- Email to a Friend
In Wall Properties, check if there is a Coarse Scale Fill Pattern.
Then in your view, set the Detail Level to Medium or Fine.
Does it now have the Concrete Fill Pattern?
St. Louis, MO
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Check if the Material is set to "Default Wall"
Go to Manage>Materials then look at Cut Pattern.
See if your wall's Material is really using Default Wall Material--or recheck the Coarse Fill setting under wall properties.
St. Louis, MO
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
Check these settings as well.
see attached.
St. Louis, MO
- Highlight
- Email to a Friend
Hello everyone, I wanted to know how do I configure my Revit Architecture 2013 software so it can save files in previous versions (2012, 2011, 2010)
thank you
- Highlight
- Email to a Friend
Revit is not Backwards Compatable......................
Mike
BIM Design Automation Coordinator
CH2M Hill
