• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Accepted Solution
    Editing view discipline settings
    165 Views, 5 Replies
    02-01-2013 05:49 PM
    Is there a way to modify the settings associated with the view disciplines?  The reason is that when a view is set to mechanical, electrical, or plumbing, a white border appears around families that blocks the lines of adjacent families.  This doesn't happen when the discipline is set to architectural, structural, or coordination.  Originally, I thought this was a glitch with view filters, but now I'm hoping that it's some kind of setting in Revit or the Revit.ini file, or somewhere else.  Please see the attached image.
    Please use plain text.
    Valued Mentor
    AJA14
    Re: Editing view discipline settings
    02-03-2013 09:41 PM in reply to: aryn
    Could you please attach your file.
    Ali Al-Hammoud
    Structural Design Engineer
    MZ & Partners Engineering Consultancy
    Active Contributor
    02-04-2013 09:33 AM in reply to: AJA14
    I can't attach a Revit project as the file size is too big, but I did attached the electrical fixture and electrical equipment families.  With Revit 2013, drop them into a new project side by side using the electrical default template and you should see the white border in the views set to the electrical discipline.  They will disappear if you change the discipline to architectural, coordination, or structrural discipline.
    *Expert Elite*
    Alfredo_Medina
    02-04-2013 09:51 AM in reply to: aryn
    It might be something with your hardware (video card), maybe. Here, I don't see any changes happening to the display of your families after changing the discipline.
    Planta1 Revit Online Consulting | info@planta1.com
    Active Contributor
    It's doubtful that it's the hardware
    02-04-2013 09:56 AM in reply to: Alfredo_Medina
    I tested 3 different workstations, all with different Nvidia Quadro Autodesk Revit approved video cards and it happens on all of them.  I also tried turning off the 3D hardware acceleration and the border is still there.
    *Expert Elite*
    Re: It's doubtful that it's the hardware
    02-04-2013 10:10 AM in reply to: aryn
    I've loaded your families into a project in Revit MEP 2013, and do see what you mean. I was able to eliminate those gaps by either changing the Visual Style to Wireframe, or by going to Electrical Settings or Mechanical Settings and disabling the option "Draw MEP Hidden Lines".
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
