Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
ELEVATIONS tab, Elevation Marks are missing?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi ,
I am beginner in using Revit.
I noticed that I don't have (ELEVATIONS) tab and also (elevation icon). See the picture. Also (Elevation Marks) in the window view are not exist.
How can I regain all these?
thanks
Jaf
Re: ELEVATIONS tab, Elevation Marks are missing?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- The Level tool is not available because the current view is a floor plan. The level tool is available only from elevations or sections views.
- Elevation views do not exist in the project browser because no elevation has been created yet and/or because this project was started without a basic template that includes some default views. If you create at least one elevation, the "Elevations" folder of the Project Browser will be created. To create a new elevation use View > Elevations.
Planta1 Revit Online Consulting | info@planta1.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your fast response.
I tried your idea(view ---> Elevation) but no positive result. But in a sample drawing , (Elevations tab) is exist.
I tried to use a template, but what I found, that I don't have any template and library. See the attach picture (as example).
Is that to do with mistakes in installation process? or there are othere reasons?
thanks
Jaf
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Probably, the installation did not finish properly, and you don't have templates?
But I don't understand why using View > Elevation gives "no positive result" to create new elevations.
The lack of templates can be fixed by finding the files and putting them in the correct folders.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you for your responses. I solved it. It was mistakes in the installation.
