• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    jessie17
    Doors will not show up in first floor plan of Revit
    991 Views, 3 Replies
    11-02-2011 01:59 PM
    So I'm having a strange issue...
    Somehow today all the doors and cased openings dissapeared in my first floor plan.
    They show up in the 3d views, sections, and second floor plan, but not in the first.
    I have checked the visibilty settings, and they are all checked and correct, and I have checked the height of my floor cut, which is adequately at 4 feet high. Additionally, if I make the detail level "fine" then the casings will show up around the wall but the wall will not show the door cut.
    The doors show up in a previous version of the model, so I'm not sure what has happened to cause the dissapearance.
    Any thoughts?
    Please use plain text.
    *Expert Elite*
    Re: Doors will not show up in first floor plan of Revit
    11-02-2011 02:19 PM in reply to: jessie17
    Check the VG settings in your view under Doors.
    see attached.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    New Member
    jessie17
    11-02-2011 03:17 PM in reply to: ccollins
    Thank you for the help. I had already checked that, but for future reference my doors had changed to the wrong level. Easy fix. Thanks!
    Jess
    New Member
    nickbaker10
    10-25-2012 12:33 PM in reply to: jessie17
    This definitly helped me out because i found my doors but how did you get your doors to go to right plan then?
