• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    *Expert Elite*
    Re: Doors in angled walls
    11-09-2012 12:58 PM in reply to: GRandall
    GRandall wrote:
    "Yes I can do that but under no circumstances do temporary dimensions function on the non ortho walls."
    Seems true - no temporary dimension on a Wall that joins at an angle with another Wall. Revit doesn't always do too well when angles are involved.
    What I did below is drag the endpoint of the Walls to make the joint with the angled Wall a right angle, and then the temporary dims become available. However, if you make the dimensions permanent and correct the Walls, the dimensions are lost. There's not much I can contribute here, so I hope this is of some help.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Please use plain text.
    11-09-2012 02:15 PM in reply to: CADastrophe
    I have found that using temporary model lines can be a great aid to locating or moving objects that are otherwise difficult to snap to or adjust using normal methods.
    SG
    *Expert Elite*
    Alfredo_Medina
    11-09-2012 03:22 PM in reply to: CADastrophe
    Probably a pinned reference plane, perpendicular to the angled wall, could be used to control the distance of the door to a corner, with a dimension.
    Planta1 Revit Online Consulting | info@planta1.com
    Valued Contributor
    11-12-2012 07:52 AM in reply to: GRandall
    Thanks for the suggestions, still a Revet newbie, I'll try them until I find the easiest. Sure seems like there should be some sort of plascement constraint for doors and windows similar to ACA;s for center, offset, etc., since Revit is purported to be the "best".
    Wish List anyone
