• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    Doors in angled walls
    482 Views, 13 Replies
    11-09-2012 11:12 AM
    When inserting doors into an angled wall how does one use constraints? There are no dimensions or snaps available that I can find, what gives?
    Please use plain text.
    *Expert Elite*
    Re: Doors in angled walls
    11-09-2012 11:18 AM in reply to: GRandall
    By angled, do you mean "tilted" in the vertical plane?
    You have to think how will this actually get built in the real world.
    Probably need some custom triangular infill walls at jambs, and a soffit at the door head.
    You are correct--there are no automatic dimensions, can't Activate Dimensions when the door is placed in a Tilted Wall.
    (Wall by Face of Mass). You will need to build another wall toward the inside/interior of the tilted wall to host the door,
    as the door seems to insert itself at the intersection of the midpoint of the door's height / opening cut.
    Cliff B. Collins
    Registered Architect/BIM Manager
    Thalden Boyd Emery Architects
    St. Louis, MO
    Valued Contributor
    11-09-2012 11:21 AM in reply to: ccollins
    No. That would be sloped I am inserting a door into a non-orthographic wall (multiple of 45 degrees). I need the on the fly dimensioning just like the orthograpic wall function.
    *Expert Elite*
    11-09-2012 11:48 AM in reply to: GRandall
    So you mean angled in Plan?
    If so, the temporary dimensions are working for me.
    Cliff B. Collins
    St. Louis, MO
    Valued Contributor
    11-09-2012 12:06 PM in reply to: ccollins
    I've attached screen shots of the issue I am seeing. Notice that the door in the horizontal wall the temporary dimensions show up but the on in the toilet wall only shows it is selected.
    Valued Contributor
    11-09-2012 12:08 PM in reply to: GRandall
    Here is the first with the temp dims.
    *Expert Elite*
    11-09-2012 12:10 PM in reply to: GRandall
    Can you select "Activate Dimensions" on the toolbar when the door in the angled wall is selected?
    Cliff B. Collins
    St. Louis, MO
    *Expert Elite*
    11-09-2012 12:26 PM in reply to: GRandall
    While using the Aligned Dimension tool, you can hover the cursor over the intersection of the faces of the angled Wall and another Wall, then hit Tab until the intersection point is highlighted (see image below). From there, you can then click on the center plane of the door and the opposite edge of the face of the Wall without trouble. You cannot select the intersection of the Wall center lines.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Valued Contributor
    11-09-2012 12:26 PM in reply to: ccollins
    Sort of. When the door is selected and the dimension is invoiked it only recognizes the jambs of the door. No wall points are available to snap to. I added other walls at differnt angles within this drawing and they functioned properly but none (30+) of the angled walls allow the exact placement of doors or dimensions.
    Valued Contributor
    11-09-2012 12:42 PM in reply to: CADastrophe
    Yes I can do that but under no circumstances do temporary dimensions function on the non ortho walls.
