• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    kwihae
    Door schedule - door swing direction
    781 Views, 4 Replies
    02-25-2012 11:23 AM
    Can you show the direction of swing in the door schedule?
    Please use plain text.
    Alfredo_Medina
    Re: Door schedule - door swing direction
    02-29-2012 07:46 AM in reply to: kwihae
    You can use "room: to", and "room: from" for that purpose, but changes to the swing will not update the schedule, because the swing does not determine which room the door belongs to.
    I have read in another forum that it is possible to write some API code to catch the orientation of the swing of the door, and keep the information updated if the door is flipped.
    Planta1 Revit Online Consulting | info@planta1.com
    Valued Contributor
    kwihae
    02-29-2012 10:28 AM in reply to: Alfredo_Medina
    I found a plug in for Revit which claims to scheule the door swing direction. I haven't tried it yet though.
    http://www.revittools.com/index.htm
    Active Contributor
    08-22-2012 09:28 AM in reply to: kwihae
    The options or methonds Revit scheduls door swings ignore industry standard terminology.  Saying that the door swings ‘Room To’ or  ‘Room From’ is not the way architects, door specifiers, and door estimators refer to swing or more properly, handing.  There are only four states of handing; right hand, left hand, right hand reverse, and left hand reverse.  All are referenced from the outside of the room, facing the door.
    Why do the ‘programers’ ignore the standards of the industry for which they are creating software?
    Gary Striyle, AIA
    Architecture Cubed, Inc
    New Member
    12-18-2012 02:26 AM in reply to: gary
    Not all... Archicad has this by default. And i hope revit will implement it in one of the future versions.
    Btw, this plugin should do the trick http://web.tools4revit.com/dynamic-legend/e-help-090511/dl-create-door-legend-with-swingdirection/
    Hope this helps.
    Vojko
