• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Divide Lines in Revit like in AutoCAD
    1343 Views, 7 Replies
    10-15-2008 12:30 PM
    Is there a way to divide lines in Revit 8.1 like you can in AutoCAD?
    *cdv
    Re: Divide Lines in Revit like in AutoCAD
    10-15-2008 12:56 PM in reply to: 2j2mattones
    Use the split tool.
    style="BORDER-LEFT: #000000 2px solid; PADDING-LEFT: 5px; PADDING-RIGHT: 0px; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px">
    Is
    AutoCAD?
    10-15-2008 01:01 PM in reply to: 2j2mattones
    I'm sorry, I should have been more specific. I meant is there a way to divide a line into even segment lengths, like the divide command would do for AutoCAD where I could just select a line, arc, circle, or polyline and have it divided into X# of equal length segments?
    10-16-2008 03:19 AM in reply to: 2j2mattones
    No. The best work-around would be to array reference lines, or drafting lines and then use the Split tool on each "intersection" This is one of only a couple of commands that AutoCAD has, that Revit does not have.
    *BIM is in
    10-16-2008 04:15 PM in reply to: 2j2mattones
    Are you looking to create equal space such as the
    divide command does or the measure command till it runs out of room?
    Option: draw your line the length you want it.
    Place your objects the total number you want along the line. Place vertical
    lines at each end of the line and then string dimensions and apply EQ. Its a
    little lengthy but should work.
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    No.
    Valued Contributor
    03-29-2011 10:50 AM in reply to: *BIM is in
    Related NOOB question (I'm switching from Autocad and am forced to speak in its terms):
    In Autocad, if I have a road centerline using a spline-fit polyline and want to find the midpoint of its length I use the DIVIDE command to divide the polyline into 2 segments and a point is placed at the middle of its length. Using Revit model or detail lines to create a similar curved line, I can see the length of the line in Properties, but don't see any way to find its midpoint (or third-points or quarter-points etc.). Is there a way to divide this curving model or detail line into equal segments? And if not, how would I go about determining the midpoint?
    Member
    StupidID
    02-06-2012 02:12 PM in reply to: 2j2mattones
    The best way is to create reference lines and array them either linear or radial to your needs then create your objects on the ref lines.
    Valued Contributor
    02-06-2012 03:50 PM in reply to: 2j2mattones
    Following is a link to what I found for more complicated line / arc combinations (look for workflow on page 2 by eddy.lermytte):
    http://forums.augi.com/showthread.php?t=10364&page=2
