• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Active Contributor
    Directx
    1028 Views, 10 Replies
    05-05-2012 07:15 AM
    I have installed DirectX SDK on my computer. However, every time I open Revit Architecture 2013 I get a message "The DirectX Software Rasterizer cannot be initialized. Please install DirectX SDK to run test properly." The program seems to run properly however.??
    Please use plain text.
    Member
    Re: Directx
    05-07-2012 12:36 PM in reply to: jbohan
    This sound like it might be a problem with you graphics card and/or graphics driver.
    What type of graphics card do you have and what version of the graphics driver are you using?
    What OS are you using?
    /Laj
    Active Contributor
    Re: Directx
    05-07-2012 05:54 PM in reply to: lars-ake.johansson
    Card: GeForce GTX 260M
    Driver: NVIDIA ver. 8.15.11.8631
    os: Windows 7
    Member
    Re: Directx
    05-09-2012 06:50 AM in reply to: jbohan
    One thing that I do see is that your driver is a bit old, that might be the problem.
    Let's start by checking if turning off Hardware Acceleration get's rid of the error:
    - Open up the Options dialog
    - Select 'Graphics'
    - Uncheck 'Use Hardware Acceleraton....."
    - Click 'OK'
    - Close Revit
    -Start Revit again
    Did you get the error? If not - I would guess that this is an issue with the driver. Check your system vendors site and/or Nvidia.com for updated driver.
    Once installed, turn on HA again and the error will most likely not appear.
    Note however that there is currently a know issue with semi-transparent materials with some Nvidia graphics card that you might run in to. We are working with NV on this issue and there will be a new driver posted (I have no ETA on the new driver)....
    If you do see an issue with this - turn off HA for now until there is a new driver that fixes this issue is posted.
    If you still get the error after tuning off HA and/or the new driver does not help , could you post a journal file here? (or send it to me)
    Just start Revit, open a new project and close Revit again.
    Grab the last Journal.####.txt (where #### is a sequential number) in:
    C:\Users\[your login name]\AppData\Local\Autodesk\Revit\Autodesk Revit Architecture 2013\Journals
    Lars-Ake Johansson
    Sr. SQA Engineer
    Active Contributor
    Re: Directx
    05-09-2012 11:33 AM in reply to: jbohan
    Still getting the message. I can't turn on the 3D accelerator. I get the message that I am in software emulation mode and that my video card and driver are not compatible with the program. However I am able to work in Revit 2013. Attached is the journal file
    Member
    Re: Directx
    05-09-2012 12:59 PM in reply to: jbohan
    Could you try something else?
    - Browse to: http://www.microsoft.com/en-us/download/details.aspx?id=35
    - Download and run dxwebsetup.exe
    Start Revit and try to activate HA again.
    If you don't get the message,
    - could you please post your last Journal-file here as well?
    For other reading this post: Please do not install the DirectX SDK - it will not help and it will only install a lot of unnecessary files on your system.
    Regards
    Laj
    Active Contributor
    Re: Directx
    05-09-2012 01:42 PM in reply to: jbohan
    The problem of the error message has been solved. However now ray tracing doesn't work well with or without HA.
    Member
    Re: Directx
    05-09-2012 01:44 PM in reply to: jbohan
    Could you please attach the latest Journal ?
    /Regards
    Laj
    Active Contributor
    Re: Directx
    05-09-2012 02:07 PM in reply to: lars-ake.johansson
    Latest Journal is attached
    Active Contributor
    RAM usage
    05-10-2012 09:07 AM in reply to: jbohan
    I have 6 GB of RAM. This doesn't appear to be enough for Revit Architecture 2013. This is especially true when I try to use Ray Tracing. I can really only do quite simple projects. Is there a work around?
