• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    Accepted Solution
    Dimensioning problems with stud walls
    341 Views, 4 Replies
    11-09-2012 08:38 AM
    Hello there
    This is a very complicated thing to explain, but I'll have a go here.
    I am having problems dimensioning internal walls with Revit 2013. Horizontally I have no issues, but when trying to dimension vertically from anywhere to the face of the core of a stud wall.
    Basically what is happening is that Revit won't recognise the core of a wall from its smallest side (wraps at ends).
    Please have a look to the attached file, For example, if I have a 63mm stud wall with a 15mm layer of plasterboard finish to either side, I will be able to put dimensions alongside the faces of the core in the long side of the wall, but I can't locate a dimension showing the 870mm lenght because the face of the ends of the wall won't be recognised by the dimension command.
    Any ideas / solutions?
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: Dimensioning problems with stud walls
    11-09-2012 09:15 AM in reply to: angelica.rodriguez
    http://screencast.com/t/RW910QhM
    Planta1 Revit Online Consulting | info@planta1.com
    *Expert Elite*
    11-09-2012 09:30 AM in reply to: Alfredo_Medina
    I believe that Angelica is referring to dimensioning the faces as per this image. They don't seem to be selectable as valid faces for a Dimension.
    Corey D.        ADSK_Logo_EE_2013.png    AutoCAD user Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    *Expert Elite*
    Alfredo_Medina
    11-09-2012 09:53 AM in reply to: CADastrophe
    Oh, sorry. Yes, for that, the only solution I think, is a locked reference plane, then dimension to the ref. plane to another ref. plane on the other side. Different video. :smileyhappy:
    http://screencast.com/t/v45V6Pmcoak
    Active Member
    11-12-2012 01:27 AM in reply to: Alfredo_Medina
    That's very good, thank you very much for that Alfredo. Here in the office we were drawing model lines and dimensioning to them, but if our wall moved or changed the dimension wouldn't change.
    Thank you very much for your help.
