• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Dimensioning 3D drafting views
    675 Views, 10 Replies
    04-09-2012 11:54 AM
    Anyone know if it is possible to create proper dimensions for 3D isometric drafting views? In AutoCAD I could set an oblique angle for a dimension but in Revit there is no setting. I can only dimension 3D model views.
    See attached PDF for example.
    Please use plain text.
    Employee
    loboarch
    Re: Dimensioning 3D drafting views
    04-09-2012 12:55 PM in reply to: paul
    Ther is no oblique dimension style in Revit.  You could do this kind of view as a 3d model view with elements hidden, a section box and the line work tool.
    Jeff Hanson
    Sr. Subject Matter Expert
    Autodesk, Revit User Experience
    04-09-2012 01:09 PM in reply to: loboarch
    I thought so. Unfortunately if you want to reuse the detail across multiple project it means recreating it each time. :smileysad:
    Valued Mentor
    vector2
    04-27-2012 11:15 PM in reply to: paul
    Possibly this is what you are looking for.
    parveen.revit
    04-29-2012 10:08 PM in reply to: paul
    it's not feasible in revit drafting view.
    intersting point to raise though...
    Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
    *Expert Elite*
    Alfredo_Medina
    04-30-2012 09:47 AM in reply to: parveen.revit
    The tip shown by Vector about changing the workplane to apply dimensions in 3D views is useful, but it does not apply to drafting views (the topic in this thread) since a drafting view is just a flat drawing with no workplanes.
    In a drafting view, you can use the regular Aligned dimension tool to fully dimension the drafting view, even if it is an isometric kind of view. The only missing feature would be the "oblique" angle, but apart from that, you can dimension everything.
    Planta1 Revit Online Consulting | info@planta1.com
    Valued Mentor
    vector2
    04-30-2012 05:23 PM in reply to: Alfredo_Medina
    Alfredo_Medina wrote:
    "drafting views (the topic in this thread)"
    Are you saying if that drawing I posted on that Revit sheet came
    from AutoCAD that it would not be a drafting view? (the topic of
    this thread). Where does it have to come from to quality as a
    drafting view? Remember they only asked for dimensions on
    a drafting view.
    Valued Mentor
    vector2
    04-30-2012 05:49 PM in reply to: parveen.revit
    parveen.revit wrote:
    "it's not feasible in a revit drafting view."
    That's correct but they didn't say anything about doing
    this in a revit drafting view.
    parveen.revit
    05-01-2012 02:04 AM in reply to: paul
    Revit is different than AutoCAD and this is one the functionalily (oblique dimensions) which Revit doesn't have.
    *Expert Elite*
    Alfredo_Medina
    05-01-2012 05:29 AM in reply to: vector2
    Not true. The original post in this thread begins with "Anyone know if it is possible to create proper dimensions for 3D isometric drafting views?"
    A drafting view is flat, even if it shows a "3d" representation of an object. Therefore you cannot dimension that drafting view by setting workplanes because it is not possible to set a different workplane in a drafting view.
