Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Dimension with curved wall issue
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There is a "mirror project" command. see attached.
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I used that command. The geometry flipped fine, but the documentation is also flipped and I don't know how to solve this problem.
Thanks, Alex
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Perhaps, instead of Linking the original project into a new project and then using "mirror project",
Do a Save-as of the original project, rename it, and then try the "mirror project" command.
( I do remember annotations sometimes not working as expected.)
cheers
St. Louis, MO
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I have done that already, but the problem is that this house has a lot of mouldings done with sweep command and the profiles are also flipped when the project is not linked.
I just could make a small project of the walls and I can upload now. Just try to dimension from the wall to the end of the arc with the option of "face of core"
Thanks Alex
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Revit's dimensioning can be a little "finiky" sometimes, but there's usually a reason. When I get in a hurry, I'll place a detail line at the point where I need a dimension and then dimension to that line. When you do have time, it's always best to hit the F1 key and go exploring and experimenting.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
alex60 wrote:...Just try to dimension from the wall to the end of the arc with the option of "face of core"...
Select the curve wall. Do Disallow Join. Then do Allow Join. Try to dimension again.
Planta1 Revit Online Consulting | info@planta1.com
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I can dimension to the stucco layer end, but in my project I need to dimension to the concrete block layer end, and it is there where the dimension is not working. See the attached image.
Thanks, Alex
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It works well here. Dimensioning by faces of core, to the point that you have indicated. (After doing the Disallow-Allow step)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks Alfredo, it worked in the initial file, but I made similar sample of walls to see if it is the solution and unfortunately it did not worked in the second set of walls. See the attached project.
Thanks, alex
