• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    Different insertion point of 2 revit files
    256 Views, 1 Replies
    10-18-2012 03:00 PM
    I received 3 revit files: one is building skin, one is interior, one is the combination of the 2 linked revit files.
    Both of the building skin and interior revit files have different insertion point because when I copy one element from one file and paste it to the other file, it doesn't align.  But the third revit file that has these files linked in it shows them aligned, how is this possilbe?
    I know it's not a good practice, but what if I want to relocate the whole thing in one to align with the other file so that it will have the same insertion point (coordinate), what's the best way to do it?
    I don't think you can do this while you are in 3d view, is that correct?
    Please use plain text.
    Product Support
    Re: Different insertion point of 2 revit files
    10-25-2012 01:34 PM in reply to: diesellam
    It sounds like the coordinate systems of the files are different (this would explain why the element you pasted didn't align as expected).
    To ensure different files will line up when linked, you can use shared coordinates.
    Shared coordinates can be a complex topic. If you are not familiar with topic, I would suggest reviewing general information about shared coordinates, and then see if you can setup shared coordinates between the files. I did a search for "Revit shared coordinates" online (without the quotes) and found the following pages with information on shared coordinates (of course these are just a few of the first results found):
    http://revitclinic.typepad.com/my_weblog/2009/06/rendering-troubleshooting.html
    http://www.aecbytes.com/tipsandtricks/2010/issue54-revit1.html
    http://www.youtube.com/watch?v=RMjfG56V4mw
    http://www.youtube.com/watch?v=vum9xSrWw84
    http://designreform.net/2009/09/revit-2010-%E2%80%93-publishing-shared-coordinates-named-views-acros...
    Lance Coffey
    Support Specialist
    Product Support
