• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    mmau
    Default Template File Invalid
    4601 Views, 2 Replies
    06-26-2011 12:04 PM
    when I start Revit it show me this message, I cant find any component in my library components, any solutions?
    It says:
    "The default template file you have specified does not exist:"
    Please use plain text.
    Employee
    Re: Default Template File Invalid
    06-29-2011 08:45 AM in reply to: mmau
    I would verify you have installed the content for Revit; under R > Options > File Locations, verify the default template file location. It is installed at the following location by default:
    C:\ProgramData\Autodesk\RAC 2012\Templates\US Imperial\default.rte
    To install content packs in Revit 2012 you need to do so in the Control Panel > Add/Remove Programs.  Here is a post with the process below:
    Installing Content for Revit 2012 products
    Thank you,
    Ryan Duell
    Autodesk, Inc.
    Revit Clinic
    @revitclinic
    New Member
    08-15-2012 07:49 PM in reply to: ryan.duell
    Hi there
    I am having the same problem (I've downloaded Revit Architecture 2012 for students) and I get an error message first saying "the default template file you have specified does not exist: C:\ProgramData\Autodesk\RAC 2012\Templates\Australia\DefaultAUSENU.rte"
    But when I look in the RAC 2012 folder it's empty...  I've done a search on templates and there don't seem to be any loaded.
    when I close that error message I get one that says: "the path you have specified for the default family template files is invalid"
    I have had IT guys looking at this but we're all a bit lost as to what to do.
    I've uninstalled it and reinstalled it 3 times to no avail.  Can you please help???  I have assignments due and I can't even start them yet!
    thanks
