• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Distinguished Contributor
    andrea.pontiggia
    Customizing hatch
    125 Views, 3 Replies
    01-08-2013 03:25 AM
    You can assign a pen width to the lines of a hatch?
    thanks
    Andrea
    Please use plain text.
    LisaDrago
    Re: Customizing hatch
    01-08-2013 06:03 AM in reply to: andrea.pontiggia
    When you create or modify a filled region (hatch) - you can control the pen. I have an image attached for reference.
    LD
    If this helped solve your issue - remember to 'accept as solution' to help other find answers!
    You can't think AutoCAD and run Revit.
    Email: lisa@kalblue.com
    andrea.pontiggia
    01-08-2013 07:51 AM in reply to: LisaDrago
    I referred to hatches automatic assigned directly to the materials, which appear for example when it dissects an element. thanks
    Andrea
    LisaDrago
    01-08-2013 08:20 AM in reply to: andrea.pontiggia
    you know - that is a really good question - I did some looking and I am not finding anything specific to control it..
    What I did find - under VV or VG you can control the pattern but not the pen weight. Image attached
    but on others you can control the pen weight. image attached.
    I looked under the object styles and was not able to find anythng there that corresponds to the patterns or lines.
    So very interesting question - maybe someone else has some ideas!
    LD
