Autodesk Revit Architecture
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Curved Ramps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Revit seems to have trouble with doing curved ramps. Is doing a floor slab and modifying sub elements my only option?
Re: Curved Ramps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Please be more specific. What curved ramp, exactly? Any samples, sketches?
Planta1 Revit Online Consulting | info@planta1.com
Re: Curved Ramps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
See the sketch attached. It' a vehicle ramp in a carpark. I presume the inside edge of the 1:6 portion will set the slope (ie when a cross section is taken through the ramp the ramp surface is level).
Re: Curved Ramps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Create 2 types of ramp, one for each slope. Use some reference planes in plans and elevation to determine elevations and distances. Use the level contraints and base offset values to locate the start and end points in the correct places. It is not difficult.
Re: Curved Ramps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thank you, much appreciated.
Re: Curved Ramps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Alfredo_Medina,
Can you describe step by step how the curved ramp is being done? I am a little new to this. I wonder if this could be done as a family, so that it is parametric? (width of ramp/ gradient of ramp)
Re: Curved Ramps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Well, the ramp tools has a Run option, which includes an Arc option. Other than that, it's a matter of entering the settings for elevations and slope, etc, and creating the sketch.
Can that be a parametric family? Yes. But such family could not serve as host for railings. Only floors, ramps, and stairs can host railings, but we can't make families in those categories.
Re: Curved Ramps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Re: Curved Ramps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
No, making a ramp and making a family are two different things that cannot be combined. Ramps are system families, and for those, we don't have templates.
Re: Curved Ramps
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Alfredo Medina,
Thanks for your reply, I guess I have found the solution to my problem. I wanted to create a custom ramp family so that it can be loaded into other projects. So what I did was I duplicated the system family and sketched the ramp out with the appropriate dimensions and gradient, I selected them and saved them as a group. When I open other project files, I was then able to load them as groups and then when I sketch the ramps, the "custom ramp families" was loaded with the system families.
Thanks again ![]()
