• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    tstewart
    Curtain wall @ sharp angles
    305 Views, 6 Replies
    02-15-2012 01:43 AM
    How do I add the curtain wall at this corner intersection?
    Please use plain text.
    Product Support
    Re: Curtain wall @ sharp angles
    02-16-2012 12:00 PM in reply to: tstewart
    If the black section of wall (in the PDF), is an actual wall family, you should be able to select the existing wall, and change the family type to the curtain wall.
    If the black section of wall from the PDF is not a wall element, then you could start by tracing a basic wall over the black "wall" elements, and then change the type to the curtain wall you want. (When I was experimenting with this, drawing a basic wall first gave better alignment of the curtain wall panels.)
    Lance Coffey
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    tstewart
    02-16-2012 12:18 PM in reply to: tstewart
    Thank you and the tips (pointed angles) are walls, although the curtain wall's mullions & glazing never display correctly. The mullions do not align with the angles, thus making the layout seem impossible.
    TS
    Product Support
    02-16-2012 02:04 PM in reply to: tstewart
    You could look at creating a separate curtain wall family type, with different panel geometry that would fit the space better.
    Lance Coffey
    Support Specialist
    Product Support
    Autodesk, Inc.
    Valued Contributor
    tstewart
    02-16-2012 02:14 PM in reply to: Lance.Coffey
    THe corner connections are the ones that are challenging. How do I designate those sharp angles?
    Active Contributor
    02-19-2012 08:03 PM in reply to: tstewart
    I would not know how to do what you are wanting in Revit, but in reality (of course you are the designer?) the frame of this curtain wall in that scale at those angles are going to be very intrusive. I would have thought mostly frame not much glass  Would you just not do it in glass & not have frames so It may be alot easier to do a curtain wall with no frames, i.e. stiles or mullions.
    sportyhd
    Valued Contributor
    tstewart
    02-20-2012 08:41 AM in reply to: tstewart
    Thank you and I will remove frames and just have glazed panels.
