Autodesk Revit Architecture
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
*Alek Sutulov
Curtain wall grid rotated
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
652 Views, 3 Replies
06-01-2004 07:49 AM
Could it be rotated? I need "horizontals" to be angled. When highlighted,
rotation option is enabled but nothing happens.
*david haynes - imaginit
Re: Curtain wall grid rotated
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-01-2004 10:36 AM in reply to:
*Alek Sutulov
When highlighted (grid turns red), you should see something like the
attached.
BTW, most of the editing processes in REVIT take different sequence of steps
than you might have done in ACAD.
Also, look at help section in REVIT for more information.
Hope this helps
_____________________________
David Haynes, AIA
IMAGINiT Technologies
Seattle, WA
"Alek Sutulov" wrote in message
news:40bc978d$1_1@newsprd01...
*Jeffrey McGrew
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-01-2004 11:45 AM in reply to:
*Alek Sutulov
David,
While Revit will highlight the curtain devision, and will look like
it gives you the ability to rotate it, you'll notice that nothing
happens when you try to do so. Revit currently can't rotate curtain
grids for some reason.
The better way to achieve this is to 'stack' several curtain walls
with edited profiles. When you edit the profile sketch of a curtain
wall in Revit, afterwards Revit will allow you to place mullions on
the outside edge of that wall. This will allow you to have mullions at
any angle/profile you wish. So if you draw your curtain wall as a
series of profile-edited walls, you'll be able to achieve quickly what
you want. It's not the most eloquent solution, and is a bit of
work-around.
Jeffrey McGrew
Application Specialist BSD
AEC Technologies, a division of ID8 Media Inc.
(415) 593-6000 x 129
(415) 593-3333 Fax
www.aectech.com
www.id8media.com
> attached.
> Hope this helps
> David Haynes, AIA
> Seattle, WA
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
06-01-2004 12:48 PM in reply to:
*Alek Sutulov
Jeff,
My mistake - my mind was on structural grids.....
Your work-around is a good one.
David
"Jeffrey McGrew" wrote in message
news:40bcceab$1_3@newsprd01...
> David,
> work-around.
> Jeffrey McGrew
> (415) 593-3333 Fax
> www.aectech.com
> www.id8media.com
> > attached.
steps
> > Hope this helps
> > David Haynes, AIA
> > Seattle, WA
highlighted,
