• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Member
    Foggo
    Curtain Wall Panel Properties
    91 Views, 1 Replies
    11-06-2012 09:16 AM
    After creating a new Curtain Wall Panel how does one go about customising the Analytical properties for future Building Performance analysis?
    Below are the figures that are returned after selecting one of the options namely
    1/2 in Pilkington single glazing
    When the panel in question is actually made up of 10mm of glass, a 16mm air gap then a sandwich of 5mm glass 0.8mm film and another 5mm glass. It is not surprising that this option is not available from a drop down menu however what is surprising is that there is no customise option which would allow the 4 figures to be entered manually
    Analytical Properties
    Analytic Construction 1/2 in Pilkington single glazing
    Heat Transfer Coefficient (U) 6.2426 W/(m².K)
    Thermal Resistance (R) 0.1602 (m².K)/W
    Solar Heat Gain Coefficient 0.81
    Visual Light Transmittance 0.88
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: Curtain Wall Panel Properties
    11-06-2012 08:06 PM in reply to: Foggo
    This has to do with the materials dialog box, and the termal properties of materials. If you are unders subscription, I suggest you do some search in the Autodesk University catalog of classes. There have been some lectures about these topics.
    Planta1 Revit Online Consulting | info@planta1.com
