Curtain Wall Doors Not Loading
I just recently upgraded to the student version of 2012 from 2011, and I'm trying to place a door in a curtain wall, but none of the Curtain Wall door families are loading.  Other door families will load, but not these ones.  Any reason why this might be happening?
LisaDrago
Just want to check to see that you are selecting the panel and using the type selector to put the door in - right. You won't see curtain wall doors under the door type selector.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: [email protected]
I restarted Revit and it worked this time.  Very strange...
LisaDrago
Yes - that is odd.... but as long as it is working that is what matters...
LD
I am having this same issue. I have restarted the program, and have restarted the computer itself. When I attempt to load a door, it will not allow it, and reverts everytime to the standard single flush wooden door. Any help?
