• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Valued Contributor
    kate_vanhout
    Accepted Solution
    Creating Wall Based Family
    200 Views, 4 Replies
    10-30-2012 02:34 PM
    I want to Create a Wall Nitch that will be in a tiled shower we are doing.  Does anyone have any suggestions on the best way to create a family that cuts into a wall? I don't want to Create an opening, because I don't want it going all the way through the wall.  I am not sure how to go about this.  Any suggestions will be greatly appreciated! :smileyhappy:
    Please use plain text.
    *Expert Elite*
    Alfredo_Medina
    Re: Creating Wall Based Family
    10-30-2012 02:45 PM in reply to: kate_vanhout
    Make a face-based family with a void, and cut the void from the sample face in the family editor. Once you load this into a project, and put it on the face of the wall, it will cut the wall.
    Planta1 Revit Online Consulting | info@planta1.com
    Valued Contributor
    kate_vanhout
    10-30-2012 02:52 PM in reply to: Alfredo_Medina
    I tried this and couldnt get it to work.  Do you have an example of one that you got to work?
    *Expert Elite*
    Alfredo_Medina
    10-30-2012 05:25 PM in reply to: kate_vanhout
    In the family editor, do Cut geometry, select the void, select the sample volume. It should cut the wall in the project, too.
    Valued Contributor
    kate_vanhout
    10-31-2012 05:31 AM in reply to: Alfredo_Medina
    Thanks so much!! I completely missed the step of using Cut Geometry. Oops!
