• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    *Expert Elite*
    Create a Detail View call-out without head, tail, or boundary line.
    1718 Views, 3 Replies
    01-05-2011 11:54 AM
    How do I place a call-out only without head, tail, or anything else?  Currently I have to create a Detail Call-out and stretch the boundary to a very small rectangle so it won't show up when print.  And I don't want fake call-outs that don't link.
    Thanks a lot.
    Please use plain text.
    Employee
    Re: Create a Detail View call-out without head, tail, or boundary line.
    01-06-2011 07:36 AM in reply to: ToanDN
    One approach could be as follows:
    1.  Manage > Additional Settings > Callout Tags > Duplicate > Name accordingly
    2.  Set Callout Head > None, OK
    3.  Add Detail Callout > Select > Edit Type > Duplicate > Name accordingly > Set Callout Tag > new type
    4.  This will remove head geometry, and then you could simply hide the dashed callout line by element in the view:
    Video Example: http://screencast.com/t/tc1EgxRlh
    Hope this helps, thank you,
    Ryan Duell
    Autodesk, Inc.
    Revit Clinic
    @revitclinic
    *Expert Elite*
    01-06-2011 08:56 AM in reply to: ryan.duell
    Thanks.  I will give it a try.
    04-07-2011 07:13 AM in reply to: ToanDN
    What if I wanted to create a new callout tag that can be placed (separately) at the end of a line of text.  Such as:  Refer to Detail 10 / A501     How would I modify a reference tag to make it work like this?
    Thanks!
