• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    *Garrak
    Copyright symbol in Revit Text field.
    649 Views, 9 Replies
    09-22-2005 07:43 AM
    There should be a way to get the Truetype font symbols into Revit. Right now
    I open Word and click on Insert>Symbol and place symbol in Word doc,
    highlight it and c to copy to windows clipboard and then switch to
    Revit and start the text command and v to paste it in the text field.
    Isn't there a more direct way?
    Please use plain text.
    *Cadkiller
    Re: Copyright symbol in Revit Text field.
    09-22-2005 09:04 AM in reply to: *Garrak
    Have you tried the keystrokes for special characters?
    Copyright symbol = Alt + 0169
    From;
    Edward Borg
    Precision Drafting LLC
    Http://Precisiondraftingllc.com
    *AlmightySR
    09-22-2005 10:30 AM in reply to: *Garrak
    Or, open up the Character Map and drag and drop your symbols in
    "Cadkiller" wrote in message
    news:4964226@discussion.autodesk.com...
    From;
    Edward Borg
    Distinguished Contributor
    09-22-2005 11:30 AM in reply to: *Garrak
    Funny...timing that is...just posted a tip about this on my blog.
    http://revitoped.blogspot.com/2005/09/are-you-special-character.html
    *Garrak
    09-22-2005 02:14 PM in reply to: *Garrak
    Alrighty!
    wrote in message news:4964535@discussion.autodesk.com...
    *bimdesk
    10-03-2005 12:31 AM in reply to: *Garrak
    Drag and drop doesn't seem to work for all symbols. Try dragging (R)
    registered and notice it appears in the text box, but once you finsh the
    TEXT command it gets converted to some funny stuff â. Any idea...
    "AlmightySR" wrote in message
    news:4964399@discussion.autodesk.com...
    From;
    Edward Borg
    10-03-2005 09:17 AM in reply to: *Garrak
    Which font are you referring to? Are you sure you've got the same font selected? It is easy to browse the wrong font and try to use a symbol from its collection.
    New Member
    06-14-2012 01:24 PM in reply to: *Garrak
    When I am trying to modify text notes, the © symbol gets inserted, but is not visible.  When I search for the symbol throughout the drawing it is visible, but in the text notes field it just creates a space instead of the symbol.  Any help would be greatly appreciated.
    parveen.revit
    06-15-2012 06:15 AM in reply to: m.viall
    it may have something to do with font or font color. plz check
    Parveen_Intec_Infocom (BIM, CAD, GIS, QS Services' Provider)
    Active Member
    12-08-2012 09:37 PM in reply to: *Garrak
    When you insert from another program such as word, the correct symbol will appear but once you click off it, the symbol reverts back to the character from the text style of the text block.  If you duplicate the style or edit it to use the correct font for the symbol you want (such as wingdings, etc.), it should work then.
