• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    New Member
    CopyRasterRegion Failed: line 464 of Source\GImageRendererOGS.cpp
    159 Views, 1 Replies
    08-22-2012 10:01 PM
    I have a workset drawing and out of sudden, when I tried to open the file, it crash and keep asking me to choose a different view. Checked on the journal file, and found the error but not too sure what is the cause. Please advise.
    I attached the journal as reference.
    'E 23-Aug-2012 12:20:34.684; 0:< Jrn.Activate "[UCTI_Campus superstructure_Jacob forsberg(Recovery).rvt]" , "Floor Plan: DO_Aras 4" ' 1:--Post event status Succeeded ' 0:< View Open: Element expansion used 2.799698 seconds averaging 0.000063 seconds/hit for 44753 hits. ' 0:< View Open: Element expansion used 0.000000 seconds averaging 0.000000 seconds/hit for 0 hits. ' 0:< CrsTimer event occurred for 1 times in DesktopMFCView [Floor Plan: DO_Aras 1] ' 1:< DBG_WARN: CopyRasterRegion Failed: line 464 of Source\GImageRendererOGS.cpp. ' 0.986609== 1:<<<;PERF;MISC;drawing 'C 23-Aug-2012 12:20:35.804; 0:< Display exception has occurred. 'C 23-Aug-2012 12:20:37.666; 0:< ADialog::doModal start 'E 23-Aug-2012 12:20:39.122; 0:< Jrn.PushButton "Modal , Views , Dialog_Revit_ViewsListOnly" _ , "Cancel, IDCANCEL" 'C 23-Aug-2012 12:20:39.139; 0:< ADialog::doModal stop 'E 23-Aug-2012 12:20:39.150; 0:< Jrn.Browser "Activate" _
    Please use plain text.
    New Member
    Re: CopyRasterRegion Failed: line 464 of Source\GImageRendererOGS.cpp
    10-12-2012 12:58 PM in reply to: kahchun.ho
    I have seen a similar warning in the journal file... this was followed by a screen flicker and a graphics driver crash. I'm not sure what it means, but hopefully someone with more knowledge will comment on this.
     'CT [Modify | Section Boxes]:
     '	{1} spacer_shr
     'Cache:
     '<<End build CT>>
     ' 0:< DBG_WARN: Raster::Map Failed: line 488 of Source\GImageRendererOGS.cpp.
