Autodesk Revit Architecture
Topic Options
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Copy / Moniter Walls
Options
- Highlight
- Email to a Friend
98 Views, 1 Replies
12-06-2012 11:14 AM
I have a model which has an Architectural Model linked in. I have successfully Copy/Monitered the Levels and Grids. However I am having trouble doing the same for the Walls. During the Copy Moniter process I can select the walls and the system seems to recognize the selection.
However, when I exit the copy tool I cannot select the walls or add a wall hosted element.
HELP???
Re: Copy / Moniter Walls
Options
- Highlight
- Email to a Friend
12-06-2012 11:27 AM in reply to:
jfitz2020
There's a separate "Finish" button on the Options Bar for selection that you must hit prior to hitting the larger "Finish" to exit the Copy/Monitor function.
If this isn't the cause of the issue, just let us know!
Corey D.
⁞|⁞ Please use the
.Accept as Solution and
Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
⁞|⁞ Please use the
