• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Revit Architecture
    Distinguished Contributor
    IMCornish
    Converting voids
    148 Views, 6 Replies
    02-07-2013 05:17 AM
    Can a void be converted to a solid?
    Andrew Robertson
    Chartered Architect
    Robertson Partnership
    Truro. UK
    Please use plain text.
    Alfredo_Medina
    Re: Converting voids
    02-07-2013 05:21 AM in reply to: IMCornish
    Yes, you can select a void, and convert into a solid, or convert a solid into a void.
    Planta1 Revit Online Consulting | info@planta1.com
    IMCornish
    02-07-2013 08:50 AM in reply to: Alfredo_Medina
    Alfredo, I was aware of this opportunity with solids to voids but 'my voids' do not seem to offer this choice, see partial screen view with a swept blend void form selected adjacent to Properties window:Void to Solid.png
    The void, although selected appears to have no properties! Any ideas please?
    Andrew Robertson
    Chartered Architect
    Truro. UK
    02-07-2013 09:00 AM in reply to: IMCornish
    Is the Void part of a Group? I've found that you do not have this option in this case - you cannot change a Void to a Solid or vice versa in Groups.
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    IMCornish
    02-07-2013 10:31 AM in reply to: CADastrophe
    No, it is not in a group.
    Andrew Robertson
    Chartered Architect
    Truro. UK
    02-07-2013 12:05 PM in reply to: IMCornish
    Also, if the Void is cutting any other extrusion, you cannot change it to a Solid. It is possible for a Void to be set to cut an extrusion that it does not even contact, so to remedy this, select the Void and then to Modify tab » Cut ▼ Uncut Geometry. Hover the cursor over the other extrusions, and if any of them become highlighted, then click to disassociate these elements. Once the Void is no longer cutting any elements, you will be able to change it to a Solid.
    IMCornish
    02-08-2013 03:49 AM in reply to: CADastrophe
    Corey
    thank you, that is the key. The void needs to be dissassociated with the object it is cutting before it can be converted. Have accepted what you have said as the solution. This advice should be documented in WikiHelp.
    Andrew Robertson
    Chartered Architect
    Truro. UK
