• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    Active Contributor
    Accepted Solution
    Controlling the font thickness/boldness for generic annotation within a family
    268 Views, 11 Replies
    01-31-2013 01:50 PM
    I have a generic annotation family embedded in a family and when I bring the family into a project, the text becomes extra bold.  If I bring that exact same generic annotation family into the same project, the text looks fine.  Please see the attached image.  The top text is the generic annotation family embedded in the electrical fixture family.  The bottom is the same generic annotation family dropped directly into the project.
    Any idea on how to control the boldness of the text of the generic annotation family embedded within the electrical fixture family?  And I have to use an embedded generic annotation family for visibility control issues.
    Please use plain text.
    *Expert Elite*
    Re: Controlling the font thickness/boldness for generic annotation within a fami
    02-01-2013 05:22 AM in reply to: aryn
    Two questions: What version of Revit are you using? Can you post your electrical fixture family here?
    Corey D.        LogoEE.png   AutoCAD user  Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    Valued Contributor
    02-01-2013 05:43 AM in reply to: aryn
    Does it plot that way or just on the screen???
    David William Edwards
    Senior Architectural Designer / BIM Manager
    Sherlock, Smith & Adams, Inc.
    Active Contributor
    02-01-2013 10:28 AM in reply to: CADastrophe
    I'm using Revit 2013 with the 2nd service update and yes I can.
    Thanks!
    Active Contributor
    02-01-2013 10:30 AM in reply to: davidwilliamedwards
    We haven't tried plotting it, but the team won't be using plots much anyways.  They care about how it looks on the screen.
    *Expert Elite*
    02-01-2013 11:25 AM in reply to: aryn
    I loaded both the Electrical Fixture and the Generic Annotation Families into a Project, and the text from both appears correct. Is the text mismatched if you load them into a new project? Also, if opened from another computer, does the text appear incorrect there as well?
    Active Contributor
    02-01-2013 04:14 PM in reply to: CADastrophe
    Yeah, I compared the tags on a different machine with a new project and it they still look different.  Weird.  Well, its not a huge deal and I appreciate the effort.
    Active Contributor
    02-05-2013 10:13 AM in reply to: aryn
    Hi guys, so the problem has gotten a bit more serious.  When we try to print a pdf, the generic annotation embedded within family is extremely grainy with most of it unreadable.  We tried printing with Bluebeam, Adobe Acrobat Pro, with resolutions of up to 1200 dpi, and I've changed every setting I could find under the printing options with no luck.  Please see the image below:
    Any ideas on how to clean up the embedded generic annotation?
    Product Support
    02-05-2013 01:37 PM in reply to: aryn
    I would suspect that the nested family is being rasterized (and this is what is causing the text to be blurry).
    Try turning any shaded elements off (within the family and / or view), and see if the issue is cleared.
    Lance Coffey
    Support Specialist
    Product Support
    Autodesk, Inc.
    Active Contributor
    02-05-2013 05:23 PM in reply to: Lance.Coffey
    Hi Lance, I'm not sure what you mean by turning off any shaded elements.  Could you please explain?
