• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Revit Architecture
    JamaL9722060
    “Continue” command for dimensions in the Revit,
    309 Views, 5 Replies
    09-15-2012 12:28 AM
    I’m not sure if there is a command like what we have in the autocad regarding the dimension “continue”
    Where it might be in the Revit?
    Jamal
    Jamal NUMAN, GIS and Civil Engineer, MSc
    e-mail: JamaL9722060@yahoo.com
    P.O.Box: 731, Ramallah, West Bank, Palestine.
    Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
    Windows 7 (Ultimate 64 bits),
    Firefox 20.0,
    Kaspersky 2013.
    Please use plain text.
    Employee
    Re: “Continue” command for dimensions in the Revit,
    09-15-2012 08:52 AM in reply to: JamaL9722060
    dimensions are automatically continuous.
    http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/1468-Document1468/1744-Annotati1744...
    Scott D Davis
    AEC Technical Specialist
    North American Sales
    Autodesk, Inc.
    Want Revit Content? Go to http://seek.autodesk.com !
    JamaL9722060
    09-15-2012 01:58 PM in reply to: davissc
    thank you for the answer.
    The issue that, the help, has no screenshots and thus no visual impact which can better assist in catching the whole idea fast.
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
    *Expert Elite*
    09-17-2012 07:47 AM in reply to: JamaL9722060
    There is no such tool. As Scott said, the dimensions in Revit are intended for continuous operation. Each consecutive click finds a new point for the next dimension segment, and each successive dimension is grouped with the first into a single entity until the tool is restarted.
    The link that was posts did not have images, but it did have two good videos. The "Dimensioning Tools" video will give you a good idea of the intended workflow with Revit dimensions.
    Corey D.        ADSK_Logo_EE_2013.png    AutoCAD user Revit user
    ⁞|⁞ Please use the Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos functions as appropriate to further enhance the value of these forums. Thank you! ───────────────────────────────────────────────────────────────────────────────────────────
    *Expert Elite*
    09-17-2012 12:04 PM in reply to: JamaL9722060
    As others have said, dimension strings are automatically continued when you are first creating them.  However, if you've finished a string (accidentally or intentionally), but would like to extend it further, select the string, then in the Modify tab choose "Add witness lines", then click on whatever else you want to dimension to.
    Similarly, if you've finished a dimension string, and want to remove some items from it without recreating the entire string, select the string, then right-click on the little blue dot that is about halfway between the dimension text and the object being dimensioned, and choose "Delete witness line".
    Better yet, read the wikihelp on dimensioning.
    Ross Kirby
    BIM Manager
    Arcturis
    JamaL9722060
    09-17-2012 01:35 PM in reply to: rosskirby
    Many thanks guys for the help. Your contribution is quite useful.
    Best
    Jamal
    Firefox 20.0,
    Kaspersky 2013.
